Door Panel Repair
Old Oct 25, 2017 | 11:58 AM
ChrisLSx's Avatar
ChrisLSx
Default Door Panel Repair
This morning I repaired the broken tabs on my passenger's door panel. As seems to be well known, the plastic tabs on the door panels that hold the push pins tend to snap off. I've seem people post different DIY home remedies. Here is how I did it.
Buy the following off ebay:
Corvette C5 door panel repair kit 1997-2004 (need 1 per broken tab)
https://www.ebay.com/itm/261191736700
4 INTERIOR DOOR PANEL RETAINERS -FITS GM C5 C6 1997-2012 CHEVY CORVETTES 346-21X (if needed)
https://www.ebay.com/itm/4-INTERIOR-...72.m2749.l2649
1997-2012 C5 C6 CORVETTE DOOR PANEL RETAINER PIN CLIP NUT HOLDER SNAP FEMALE (if missing any like I was)
https://www.ebay.com/itm/121043790550
The door repair "kit" is just a piece a stamped and bent aluminum (someone COULD always make them if they so desired) and are a bit expensive, but they work PERFECTLY. Slip right on as advertised and once the retainer pin is inserted in the tab, they are tight. It takes longer to remove/install the door panel than it does to do the "fix" and these will never crack/pull lose/not adhere correctly/etc.
For me, I'm planning to buy up enough to repair every tab on both doors (so 12 in total) and put them in a box for future repairs.
Old Oct 25, 2017 | 02:23 PM
CactusCat's Avatar
CactusCat
You sir, are a crafty devil. Thanks!!!
Old Oct 25, 2017 | 02:50 PM
Robrote's Avatar
Robrote
I'm getting ready to swap out my torn door panel for a replacement I picked up from a forum member. It to has a broken retainer and I saw these online. Can't believe they're 20 bucks but I'll get one and certainly see if I can reproduce them for a fraction of the cost.
Old Oct 27, 2017 | 02:01 PM
huesmann's Avatar
huesmann
CamaroGuy, any chance you could pull the relevant dimensions off one of those folded U thingies?
Old Oct 28, 2017 | 09:36 PM
ChrisLSx's Avatar
ChrisLSx
As soon as I get another one in my hand (it's been ordered), I'll snap some pics and put together some dimensions. With that said, if someone starts making these, I want to be in on testing
Old Oct 28, 2017 | 10:34 PM
Great find and thanks for posting up the details.
Old Oct 29, 2017 | 05:45 PM
Mickeyrx70's Avatar
Mickeyrx70
Old Oct 29, 2017 | 05:51 PM
ChrisLSx's Avatar
ChrisLSx
Feedback after using for a few days = they work wonderfully! This cured my squeaky door panel.
To Door Panel Repair
