Ambient temp sensor problem
Nov 1, 2017 | 03:39 PM
4th Gear
Sensor normally always reads 69 and that causes no problem but when it goes to -14, my ac will not come on. only heat in South Texas when outside temps are in the 90's
Nov 1, 2017 | 03:41 PM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
moving to C5 Tech
the sensor underneath by the radiator (right front) is bad, connection is loose/bad
try removing it, cleaning and plugging back in
I will try and find the reset procedure for the unit too and post it here
Nov 1, 2017 | 03:43 PM
4th Gear
Quote:
Originally Posted by
pewter99
moving to C5 Tech
I did buy a new one and plugged it in but did not calibrate or anything to reset
Nov 1, 2017 | 03:46 PM
When the Front Defrost, Rear Defog and fan up buttons are pressed simultaneously. Updates temperature display instantly
Nov 1, 2017 | 05:34 PM
4th Gear
pewter99
when I did that it went to -40. any more suggestions? thnaks
Nov 2, 2017 | 07:26 AM
Check the connector and wiring. The sensor isn't connected to the control unit.
Nov 2, 2017 | 09:58 AM
4th Gear
lionelhutz
Is there a second connection between sensor and control unit other than where sensor plugs near radiatior passenger side that I can check?
Nov 2, 2017 | 03:43 PM
ok, sounds dumb but.....have you tried disconnecting the neg battery cable for 5 minutes and reconnecting
many things on the C5 will reset when you do this when all else fails
