Harmonic balancer
Old 12-04-2017, 12:46 PM
foggy
foggy's Avatar
Originally Posted by Millenium Z06
Dont use the ARP lube, mine backed back out using the lube and 240lbs. I ended up using red locktite 262 and keying the balancer (ATI) then put witness marks on the bolt and balancer. It hasn't moved since
Do NOT put the lube on the THREADS !! Just under the head so
it doesn't affect the torque value as it meshes with the balancer.
Blue loctite on the thread. ARP lube or similar on the underhead of
bolt flange.. Proper installation
The following 3 users liked this post by foggy:
ArmchairArchitect (12-06-2017), oelarse (12-04-2017), zone-7 (12-04-2017)
Old 12-04-2017, 04:39 PM
pjdbm
pjdbm's Avatar
I called the tech support today to clarify this, spoke with Martin
He says to install this Crank Bolt as per specs on the sheet
I told him maybe he or one of his tech support staff should visit this site to debate this issue. his reply was that " you are going to listen to people on car forums about how to prepare & install OUR bolts?"
Old 12-06-2017, 08:30 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
What you're suggesting, is to NOT follow the instructions from ARP, which you happened to post, and instead apply a fairly PERMANENT thread locking compound???
Old 12-06-2017, 10:10 AM
ArmchairArchitect
Banned Scam/Spammer
ArmchairArchitect's Avatar
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes on 1,616 Posts
Sounds like he didn't bother to explain the science/technical reasons of why the lube should used (especially on the threads).
Old 12-06-2017, 12:16 PM
leadfoot4
leadfoot4's Avatar
FWIW, the lube is there to ensure that there's no additional friction between the parts, preventing the proper torque value from being achieved.
pjdbm (12-06-2017)
Old 12-06-2017, 12:36 PM
pjdbm
pjdbm's Avatar
^^^ yes, and doing so consistently
This was researched before I purchased this, there is a good vid on there site that demos this
Old 12-06-2017, 12:52 PM
GoldenFlame
GoldenFlame's Avatar
I've never had a problem with an ARP crank bolt backing out following their directions.. of course I replaced my balancer and bolt before ever having an issue with it.
Old 12-06-2017, 12:56 PM
Gordy M
Gordy M's Avatar
Remember if you use any lubricant on the threads of a bolt you will end up with different amount of holding power (bolt stretch) as a result. If ARP says to use the material on the end of the bolt and not the thread, then it will have a higher clamping force than lubricating the thread will have. More than likely that is the reason the bolt came loose.
Old 12-06-2017, 01:06 PM
zeevette
zeevette's Avatar
Again, just pin it.
Old 12-06-2017, 05:58 PM
leadfoot4
leadfoot4's Avatar
Did you read what ARP's instructions stated, as posted by the two previous posters? It clearly states to lubricate both the underside of the bolt, and the faces of the washer, AS WELL AS the threads. I have a strong suspicion that ARP knows what they're talking about..........
SG Lou (12-11-2017)
Old 12-10-2017, 05:11 PM
Millenium Z06
Moderator
Millenium Z06's Avatar
Instructions clearly say to use on the threads too.
I cleaned the bolt and the crank with brake parts cleaner, keyed the balancer and used locktite 262 and it hasn't moved since
Oh, thanks for the video, yours is the one I used for instructions the 1st time
Old 12-10-2017, 05:14 PM
Millenium Z06
Moderator
I quoted someone else whom posted the instructions. And yes, 262 (or blue 242 if you prefer) on the threads. I found 2 ARP instructions since mine came off, one said to use the lube, the other said red 262. I did the red 262 after the 1st instructions failed. This isnt a job you want to do too many times and I've done it 3 times now
Old 12-10-2017, 05:16 PM
  #33
Millenium Z06
Moderator
I followed their instructions twice and mine backed out. 3rd repair hasn't moved
Old 12-11-2017, 07:19 AM
  #34
leadfoot4
leadfoot4's Avatar
I followed their instructions (lube bolt head and threads) 2 years ago, and so far, my bolt hasn't backed out. Personally, and this is just my opinion, I don't see how a bolt that's properly torqued to 240 ft/lbs is going to "back out". MILLIONS of previous generations of small block Chevrolet engines have had a single bolt, torqued to 60 ft/lbs, holding their balancers in place.....
SG Lou (12-11-2017)
Old 12-11-2017, 12:55 PM
  #35
Millenium Z06
Moderator
Yet its a common problem.
I initially torqued it down to 245 then ARP said go 260. This was with an ATI balancer. My guess is that the friction wasn't enough to keep the balancer from moving and it spun, as it spun it backed the bolt out.
After I keyed the balancer and locktited the bolt, no more problems. Given that its not likley ill need to pull it apart again, im not concerned about using locktite and if I need to, I have a torch and a long breaker bar and a 650lbs impact gun
Old 12-11-2017, 01:58 PM
  #36
GoldenFlame
I'm sure your internals will love that impact gun
Old 12-11-2017, 04:13 PM
  #37
pjdbm
pjdbm's Avatar
I purposely did this job myself without a life so I was to ensure no impacts touched my vehicle and everything was torqued down properly.
I feel better and saved a few dollars
To Harmonic balancer
Old 12-11-2017, 05:52 PM
  #38
SG Lou
SG Lou's Avatar
I have a HB replacement in my near future...only thing I dread is being able to get that 240 lb/ft of torque while lying on my back with the car only 2 feet off the ground, not to mention finding a torque wrench that can achieve that torque !
Old 12-11-2017, 06:14 PM
  #39
pjdbm
pjdbm's Avatar
You can do the loaner program at Autozone but there torque wrench has a thick handle where you can’t add a cheater pipe. I got to 240 with my legs & feet! From the bottom lying on my side
Old 12-11-2017, 11:38 PM
  #40
tekhombre
tekhombre's Avatar
If you are going to the trouble of putting on a new Harmonic Balancer then you should take the extra step of pinning the crank. While the stock balancer may still have the problem of separating you will not have any problem if the crank bolt will work its way loose. For those of us who autocross in the stock class, we have to use the factory HB and bolt, when installing a new OEM bolt you end up with more than 240 ft-lb of torque. My brother-in-law is a truck mechanic and we were using all of his 360 ft-lb torque wrench to get those last 5-6 degrees.
So true, we pin every HB we install.
Quick Reply: Harmonic balancer
