OK guys here's my issue I have a 2001 with Drivers side SCM 10435193 it have a 2 plug harness I purchased some seats out of 1998 that worked fine when removed. it has a 1 plug harness with SCM 09360841, So I swapped too the two plug harness and used scm 09360841, the lumbars work but no seat track movement.. Unfortunately the 10435193 is water damaged. I have power and ground in the black plug,but nothing out of the blue..
Odd on the harness difference. I googled images of both part numbers and the connector spots on both look identical. In fact, the modules look identical except for the part numbers on the stickers. I didn't see any reason why you couldn't swap one for the other. I'd try the 98 module and see what happens.
I'm not sure if the pin out is different for the '97-'98 because I don't have a schematic for them.
When I get a chance I will check to see if a 10406008 will work if you want. They seem to be more available. They don't have the memory feature and are used on the passenger side of the later year Vette's.
