Ram clutch ?'s....
Old Oct 9, 2002 | 09:31 PM
FRC21's Avatar
FRC21
Default Ram clutch ?'s....
Are you running your RAM with the stock flywheel?
Who did you order your RAM from?
Which part numbers did you go with?
How much was the clutch?
Does it chatter much?
Old Oct 9, 2002 | 10:41 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Ram clutch ?'s.... (FRC21)
I'm not running this clutch (no need YET :D ) so I can't answer about how it feels.
But I do know this :)
Pressure plate RAM-402
Disk RAM-6130
Summit has both for under $350 shipped
Run the Z06 slave cylinder GM #12562767
re-surface stock flywheel.
Someone correct me if I'm wrong
Old Oct 10, 2002 | 12:49 AM
ChevyChad's Avatar
ChevyChad
Is it okay to run this clutch with the stock master & slave cyllinders? :confused:
Old Oct 10, 2002 | 01:16 AM
C5-VERT's Avatar
C5-VERT
Default Re: Ram clutch ?'s.... (ChevyChadZ28)
Lookup C5Noir, he has all the Ram #'s memorized! :lol: Seriously he is the guy to talk to about any Ram interest. :cheers:
Old Oct 10, 2002 | 01:26 AM
6500RPM's Avatar
6500RPM
It is pretty much a necessity to use an adjustable master cylinder with any clutch so you can get a precise engagement setting. Mcleod makes a great one! If you have a 2001 or newer then you can use your stock slave cylinder but if it is a 2000 or older, get the ZO6 slave cylinder. The RAM clutch is next on my list when my CARTEK clutch goes.
Old Oct 10, 2002 | 01:37 AM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
Just curious, anyone knows the price of the ZO6 slave cylinderÉ
Old Oct 10, 2002 | 01:43 AM
6500RPM's Avatar
6500RPM
Default Re: Ram clutch ?'s.... (Tuan Le)
Tuan, the ZO6 slave is $100 at MTI.
:cheers:
Old Oct 10, 2002 | 01:52 AM
Former Vendor
Default Re: Ram clutch ?'s.... (6500RPM)
Thanks. Has anyone try the RAM clutch with the Cartek adjustable master cylinder (which actually is a modified GM master cylinder)???
Old Oct 10, 2002 | 02:06 AM
FRC21's Avatar
FRC21
Thanks guys. I assumed I needed the adj. master. What are the part numbers, and can I get the setup from summit?
Old Oct 10, 2002 | 08:05 AM
Flyin'Brian
Cruise-In I Veteran
$84 shipped at gmpartsdirect P/N 12562767
$70 before shipping
[Modified by Flyin'Brian, 6:08 AM 10/10/2002]
Old Oct 10, 2002 | 12:34 PM
C5Noir's Avatar
C5Noir
Yes, resurface the stock flywheel.
Who did you order your RAM from http://www.summitracing.com
Part #s:
RAM-402
RAM-6130
$329 shipped
Initially it did for about 500 miles, now I have none.
You'll also need an adjustable master cylinder of choice, whether it be Cartek, McLeod or if I had to do over again the one from APRacing (sold by moreperformance.com)
The only mod you have to do the the clutch is to take a 15/64 drill bit and just drill out the three smaller pressure plate holes on the pressure plate so all of the 6 pressure plate bolts fit. Use red loctite on the flywheel and pressure plate bolts.
The ZO6 slave can be had the cheapest from:
Chris Slack of TeamChevrolet
chriss@teamchev.com
Tell him Levi Procter referred you and he'll hook you up.
Have an installer that has done many C5 clutch installs before do it. If you are doing it yourself please contact me for the MUST DO's for ANY C5 clutch install so that it works correctly!
To Ram clutch ?'s....
