FUEL PUMP - IS THIS A COMMON PROBLEM???
Old Oct 10, 2002 | 02:59 AM
AUGUSTAC5's Avatar
AUGUSTAC5
Default FUEL PUMP - IS THIS A COMMON PROBLEM???
My 98 C5 has 24k, and today the dealer tells me my pump is only measuring 30 psi. What should the pressure be? No "service engine soon, or any warning signs." The car would start, but would die within 5-7 seconds. "Newbie, trying to learn."
Old Oct 10, 2002 | 09:42 AM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: FUEL PUMP - IS THIS A COMMON PROBLEM??? (AUGUSTAC5)
It should be close to 60 psi. I think the 98s have an external fuel pressure regulator. That could also be your problem.
Old Oct 10, 2002 | 06:33 PM
alanh's Avatar
alanh
If the regulator is leaking and won't hold the fuel until the pressure reaches approx. 60#, it doesn't make any difference how good the pump is, you won't have the right pressure. If you shut the engine off with the pressure gage on the fuel rail, and the pressure leaks down to "0", it's probably the regulator. It's the cheapest of the two things to replace so try a new regulator first.
Old Oct 10, 2002 | 11:17 PM
AUGUSTAC5's Avatar
AUGUSTAC5
Thanks for the input.
To FUEL PUMP - IS THIS A COMMON PROBLEM???
