ABS & Traction Control Light on
Old Dec 6, 2017 | 09:06 PM
C5vetteproject's Avatar
C5vetteproject
4th Gear
Default ABS & Traction Control Light on
On my 2000 C5, I do not get any codes being thrown yet the ABS and Traction control light is on the dash. I found two rear speed sensors not producing any A/C voltage so i replaced the hubs/speed sensors. Does the light go out after a certain amount of mileage? Or is there a way to reset this?
Old Dec 7, 2017 | 12:03 AM
BigGun's Avatar
BigGun
A typical hand held code reader will not see these codes. You have to pull the codes using the dic. You will also be able to clear the codes and see if they come back. Here's how.
http://www.c5forum.com/ayc/dtcdic.php
Old Aug 11, 2025 | 10:36 AM
Mark2000C5's Avatar
Mark2000C5
8th Gear
Thanks. I have a Fox NT510Elite that i own software for Lexus, BMW, and VW. I guess i could spend the $95 on the GM software but need to see if it's compatible.
Appreciate the feedback
Mark
To ABS & Traction Control Light on
