Remote key fobs have lost their memory.
Old Dec 11, 2017 | 04:35 PM
C908's Avatar
C908
Default Remote key fobs have lost their memory.
I just replaced my Red Top battery now my remote key fobs quit working. I went and bought a new battery for my key fob but it made no difference. Nothing works, doors don't work, trunk release doesn't work, panic button doesn't work. I checked the settings and also checked for codes, I have none. Any ideas on how I can get the memory back. Thanks !
Old Dec 11, 2017 | 04:42 PM
Paul Wood's Avatar
Paul Wood
All you need to do is to re program the FOB. In the handbook there is a procedure. If memory serves all you do is turn on the ignition, clear all messages on DIC then go to the options button and scroll through to FOB learning. I believe all you do then is press lock and unlock at the same time. Done. I may have the location of the FOB learn menu is but the drivers manual will tell you. Good luck!
Old Dec 11, 2017 | 05:08 PM
C908's Avatar
C908
You are absolutely correct, Thank you for your quick response. I actually had looked in my manual but did not go far enough to see Fob Training. I found it and was able to program both fobs with no problem. I'm back in business. Thanks again and Merry Christmas !
Old Dec 11, 2017 | 05:19 PM
Paul Wood's Avatar
Paul Wood
Great brother! Glad the information helped. Merry Christmas to you and yours!
To Remote key fobs have lost their memory.
