C5 Door Rattle
Old Dec 13, 2017 | 02:46 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default C5 Door Rattle
My 98 doors rattle when I close them. Like the window glass mechanism inside is loose. Is there a tutorial on how to disassemble the doors and what to tighten up?
Also, my passenger side door hinge seems to bind up when I open it all the way and go to close it. What and how do I adjust them?
Old Dec 13, 2017 | 03:09 PM
Rob 02's Avatar
Rob 02
For the door hinges I use GM super lube part number 12346241. It is the only thing that seems to work long term for squeaks. It goes on thin and thickens to a Teflon grease. It is handy for a lot of other stuff too.
Amazon Amazon
As for the rattling, here is a video.
If you find broken tabs on your door panels these can fix it.
https://www.ebay.com/itm/1997-thru-2...72.m2749.l2649
Here are the fasteners
Amazon Amazon
Amazon Amazon
Old Dec 14, 2017 | 10:49 AM
Moved to C5 Tech.
Old Dec 15, 2017 | 10:03 AM
lionelhutz's Avatar
lionelhutz
Only thing I found to help glass rattle was a new outer weatherstrip.
Still, I would first adjust the window so the top edge of the window is between the weatherstrip and inner door panel felt when it is down all the way. Being between those is what gives most of the support to the window.
Old Dec 15, 2017 | 01:17 PM
zone-7's Avatar
zone-7
Had a similar door rattle. In my case it turned out to be the thin plastic access panel. It became brittle over time and broken into shards within the door panel. It sounded like the jingle of shards of broken glass whenever the door was closed or going over bumps.
I've fabricated a replacement panel out of 1/8" plex (really easy) and along with other related work, the door rattle when closing or going over road irregularities are gone.
Old Apr 9, 2022 | 07:15 PM
oktx's Avatar
oktx
My driver side is making that awful rattle when you shut the door with the window down. I can't remember how to make the window stop between the felt strips. Any help? Thanks!
To C5 Door Rattle
