1997 Corvette Grind in First Gear
Old Dec 13, 2017 | 11:16 PM
jeffwest5599's Avatar
jeffwest5599
Default 1997 Corvette Grind in First Gear
1997 corvette manual 6 speed. There is a grind underneath when I put load on clutch in first gear only. No grind if clutch is let out slowly in first with no load. However, if using on a hill and giving gas while clutch still partially engaged it is aike a grind almost scrape sound. No issues with gears and clutch works fine. All gears are fine to include reverse. Only does this in first under load. As car warms it gets worse. Any thoughts.
Old Dec 14, 2017 | 06:40 AM
jeffwest5599
Default Grind in First
an addition. If I try to start in second it does it as well. Basically it is if I put load on the clutch when driving from a stop. When moving no issues at all or if clutch is let out easy. Just trying to see if it is a clutch or tranny issue.
