Corvette C5 1997 PCM replacement
Old Dec 14, 2017 | 01:22 PM
gepeto's Avatar
gepeto
5th Gear
Default Corvette C5 1997 PCM replacement
Hi everybody,
Last day, my car ( a 1997 corvette C5 ) started to react in a funny-scary way .
Lucky me, I was just few miles away from the car shop where I use to go .
I do not remember exactly the codes but it was a MAF problem with a 5V missing from the PCM module .
After looking at this module, they figure out that the battery leaked on it and we could see some corrosion .
We are trying, since, to rebuilt the PCM ( but nobody wants to do it ), or to find another one .
But it looks that the 97 model is kind of unique and no way to find a replacement . Nothing on internet, ebay or at GM .
Just asking if somebody has a lead to find one ( model 16232148 or 19143656 . ACDELCO part 218-12290 ) ?
Or is it possible to adapt a newer version ?
I know that the cabling is not the same . Is it possible to find some adapter from the 97 harmless to another one ?
Jean Pierre
Old Dec 14, 2017 | 02:13 PM
Moved to C5 Tech.
Old Dec 14, 2017 | 05:18 PM
Corvette#2's Avatar
Corvette#2
There is one on ebay.
https://www.ebay.com/itm/NEW-Program...1iG-OQ&vxp=mtr
Old Dec 15, 2017 | 02:39 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Have you tried Gene at Cultrag/GM Parts 484-334-8833
or maybe Mark at Vettenuts (USED) 484-334-8833
mike v
Old Dec 15, 2017 | 03:02 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
OP: Great leads for you from both Corvette#2 and mike v!
Old Dec 15, 2017 | 03:09 PM
gepeto's Avatar
gepeto
5th Gear
mike v
Thanks mike v
Will try
Old Dec 15, 2017 | 03:11 PM
gepeto's Avatar
gepeto
5th Gear
Had seen it . But price seems very high . tried another alternative .
But kept it if I could find anything else
JP
Old Dec 15, 2017 | 05:17 PM
Corvette#2's Avatar
Corvette#2
mike v
Looks like Cultrag has a remanufactured one for only $150.
https://www.cultragfactoryparts.com/...odule-19143656
To Corvette C5 1997 PCM replacement
