One side hot other side cold
Old Dec 18, 2017 | 10:51 AM
Trkdrvr's Avatar
Trkdrvr
Default One side hot other side cold
Turn on AC yesterday,diver side vents blew cold.Passenger side blowing hot. Temp control ***** both turned max cold.any ideas?
Old Dec 18, 2017 | 01:31 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
In the search above type in c5hvac One side hot other side cold
You will find lots of info to get you going in the right direction
mike v
Old Dec 18, 2017 | 09:10 PM
BigGun's Avatar
BigGun
You need to pull the codes using the dic. You likely have a bad actuator that will need to be replaced.. Sometimes they can be reset but you need to codes to see if that is the problem.
Old Dec 18, 2017 | 11:17 PM
Trkdrvr's Avatar
Trkdrvr
Ok thanks I'll do that this weekend
To One side hot other side cold
