2004 corvette will not turn over
Old Dec 20, 2017 | 10:52 PM
jerchit's Avatar
jerchit
1st Gear
Default 2004 corvette will not turn over
i turn key to start all i get or here is a slight klick in the dash
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
battery
Old Dec 21, 2017 | 06:22 AM
tbrowne's Avatar
tbrowne
The battery is generally the cause. If it's cold, 30° F or less, the battery loses cranking power. If the car has been sitting for a while or the battery is old, then it could be low on cranking power. The only way to know is to test it with a voltage tester or put a battery in the car that is known to be good. I wouldn't look into other causes until I was sure it wasn't the battery.
To 2004 corvette will not turn over
