Where to find a new output shaft circlip?
While replacing my differential output shaft seals today, I noticed my passenger side output shaft is missing the circlip that holds the cv axle. I assume it's been this way for quite a while and hasn't caused any issues, but I'd like to get a new circlip if I can.
I've been searching and can't find a part #. Even looking at the exploded parts diagram on Cultrag, it doesn't appear to be listed separately.
Any thoughts on where to get one?
Yea, that would be fine, but I can't seem to find even generic ones listed anywhere. I'd even be willing to buy an assortment kit if I had too.
I've gotta be looking in the wrong place or using the wrong keyword or something because I can't be the first person to need one of these clips.
Try McMaster-Carr, when you select a part the drawings can be viewed where it says product detail; https://www.mcmaster.com/#retaining-rings/=1auqf2o.
Cruise-In VI Veteran
https://www.corvetteforum.com/forums...ring-gear.html
Part Number: 12369463 ; 08685521
(Pack of 5)
RING,DIFF P/GR SHF RET(05.422). RING,FRT WHL DRV SHF RET(05.422). RING,R/AXL SHF BRG RET.
And they are available as I just purchased two of them for my Differential Rebuild.
Cheers,
Goose
bigmackloud (12-26-2017)
The retaining ring is item number 26 and 33 in this post
(Pack of 5)
Cheers,
Goose
(Pack of 5)
Cheers,
Goose
You... da... man!
That's a different/better parts diagram than the one I found. Thanks again!
