Exhaust help
Exhaust help
So, I think I blew a baffle apart on one of my stainlessworks mufflers. It isn't hampering the performance, but is loud as hell. Can anyone help me with brands of mufflers that are slip fit over the axle, vs. bolt on??
I've been looking, but can't find any.
Tia
Tia
I have been looking also.....have not seen any new mufflers for sale without the over axle pipes. Definately a market demand. I have 2 stock systems that I would like to cut off the stock mufflers and install some performance mufflers to the over axle pipes.
I should have been more clear. I'm not looking for just mufflers, although that could solve my problem. I'm looking for mufflers with the over axle pieces. I just need them to be slip fit onto the mid pipes instead of bolting to the mid pipes like the stock exhaust does.
Did you cut out that section somehow?
It's entirely possible I'm an idiot. After looking at some of the systems Stainless Works has on their website, I'm thinking I have bolt on, not slip fit mufflers. It's been a few years since I put the exhaust on and haven't looked at that section since. I'm gonna jack the rear end up tonight and double check.
I'll bet when you get under there you will find one of your pipes it broken off from the flange. It sounds like a AA/Fuel dragster when that pipe breaks. I used to take it all off and bring it to a welding shop where they did a beautiful welding job. It lasted 3 years. Now I just take it to the neighborhood Midas shop. It also lasts 3 years between breaks but its less trouble for me.
