Parking brake malfunction
Old Dec 30, 2017 | 09:55 AM
TravisSchoech's Avatar
TravisSchoech
Default Parking brake malfunction
Hey fellas,
2003 Z06 with 100k on the clock.
I don't drive it much, maybe 1500 mi in the last year and a half.
I moved it out of the garage the other morning and when I applied the parking brake, there was no resistance. I can just rack the lever up and down with no application of the parking brake mechanism.
If I put pressure on the lever to the PASSENGER side direction WHILE pulling up, it will grab and apply the brake.
But it will not work if just pulling the lever normally.
Is there a mechanism in the pivot area that is prone to breaking on a "high mileage" car?
Just looking for ideas before I pull the center console/seat or whatever it takes to get to it.
Thanks in advance!
Old Dec 30, 2017 | 10:19 AM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Check the pawl under the cover next to the passenger seat. I read the old lube can make them hang up.
Old Dec 30, 2017 | 11:07 AM
Moved to C5 Tech.
Old Dec 30, 2017 | 11:18 AM
lionelhutz's Avatar
lionelhutz
There is a racheting mechanism to take the slack out of the cable. As posted, old dried up grease can make it stick and not ratchet. So, take the lever assembly out, wash out the old grease and re-lube it.
To Parking brake malfunction
