ABS Module
Old Jan 4, 2018 | 07:33 PM
ronfawcett's Avatar
ronfawcett
1st Gear
Default ABS Module
We have a 99 Convertible with approimately 120k miles. Our ABS Electronics Module failed. My Chevy dealer cannot find a replacement (salvage, rebuild, etc.)
Has anyone had this issue and solved the problem?
Old Jan 4, 2018 | 07:41 PM
Tsumi's Avatar
Tsumi
This will most likely get moved in to the tech section.
You can attempt this: https://www.corvetteforum.com/forums...m-success.html
Old Jan 4, 2018 | 08:56 PM
Old Jan 4, 2018 | 10:52 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by 8VETTE7
Yaw Rate sensor and Lateral Acceleration sensor and their respective wiring harnesses are not installed in the car.
FYI, there are 2 extra wires on the early SWPS that can be used for these sensors. The power and ground needed are already at the SWPS. So no extra wires have to be run from the cockpit to the module.
Old Jan 5, 2018 | 10:31 AM
waupachino's Avatar
waupachino
This company states they can repair it. https://www.ebay.com/itm/97-98-99-00...hXFPwd&vxp=mtr
Old Jan 5, 2018 | 12:50 PM
lionelhutz's Avatar
lionelhutz
Many have claimed they can fix them but none so far have been able to actually fix them.
To ABS Module
