Check this out
Old Jan 5, 2018 | 07:59 PM
Trkdrvr's Avatar
Trkdrvr
Default Check this out
2000 coupe, step on the break peddle,driver seat raises up! Doesn't matter if car is in motion or not.
Old Jan 6, 2018 | 08:41 AM
LannyL81's Avatar
LannyL81
Double post.
Old Jan 6, 2018 | 08:44 AM
LannyL81's Avatar
LannyL81
Does the seat raise up due to the seat motor or just due to your leg pressure when pressing the brake pedal.
If just leg pressure, time to remove the seat to see what has broken; most likely one of the mounting ears of the seat rail. Search YouTube to see how to fix.
Now if due to the seat motor....that would be an interesting electrical problem!!!
Old Jan 6, 2018 | 09:31 PM
Trkdrvr's Avatar
Trkdrvr
No it's the seat motor, it's weird.
Old Jan 6, 2018 | 09:33 PM
grantv's Avatar
grantv
Every time you press the brake pedal the seat moves!? Even if the car is sitting still? Have you tried turning off the easy entry?
Old Jan 6, 2018 | 09:36 PM
Trkdrvr's Avatar
Trkdrvr
Ummmm no, had the car two years.if it has to do anything with the fab,it doesn't work at all never has.no not of what you said
To Check this out
