When tightening the M10 main bolts, do you fully tighten the 10 inner bolts including the torque angle step, before tightening the outer bolts any at all?
or
Do you torque the inner bolts to 15 ft-lbs and then tighten the outer to 15 ft-lbs, before you torque angle the inner and then torque angle the outer?
From the FSM:
1.Tighten the inner bolts (1-10) a first pass in sequence to 15lb ft.
2.Tighten the inner bolts (1-10) a final pass in sequence to 80 degrees.
3.Tighten the outer studs (11-20) a first pass in sequence to 15lb ft.
4.Tighten the outer studs (11-20) a final pass in sequence to 53 degrees.
5.Tighten the side cap bolts to 18 lbft Tighten the bolt on one side of the bearing cap and then tighten the bolt on the opposite side of the same bearing cap
from the fsm:
1.tighten the inner bolts (1-10) a first pass in sequence to 15lb ft.
2.tighten the inner bolts (1-10) a final pass in sequence to 80 degrees.
3.tighten the outer studs (11-20) a first pass in sequence to 15lb ft.
4.tighten the outer studs (11-20) a final pass in sequence to 53 degrees.
5.tighten the side cap bolts to 18 lbft tighten the bolt on one side of the bearing cap and then tighten the bolt on the opposite side of the same bearing cap
