C-5 Charging issues
Old Jan 14, 2018 | 06:03 AM
wtcote's Avatar
wtcote
3rd Gear
Default C-5 Charging issues
Having charging issues with my 2004 C-5 Corvette. Normally my Battery voltage gauge is at 12.5 to 13 when running. (less at low rpm - higher at high rpm. Of recent my gauge runs between 13.8 and 14.3 the majority of the time. A local battery shop determined that my 4 year old battery was getting tired and needed replacement which I did. I charged the battery for 24hrs with a small trickle charger. Nothing has changed. Is it possible to overcharge the new battery and cause damage,? What concerns should I have if any.?
WT Cote
Old Jan 14, 2018 | 08:48 AM
Moved to C5 Tech.
Old Jan 14, 2018 | 09:16 AM
01pewtervert's Avatar
01pewtervert
Were you having a problem, or just concerned about the voltage? 12.5 is a little low, unless it's idling with accessories on. 13.8 to 14.3 is completely normal.
Old Jan 14, 2018 | 09:53 AM
coia96vette's Avatar
coia96vette
I agree. My '04 puts out 13.6 to 14.3. I keep it on a maintainer when not driving it. This time of year that is most if not all the time.
To C-5 Charging issues
