Hi Bill Curlee. I posted a few months ago. about my elec. issues. I have replaced the coolant temp sensor, cleaned the door connectors multiple times, cleaned the chassis ground plugs by the front of engine, `03 Z06 70,000 miles. car will be fine for a few hundred miles, now the latest is the car will misfire, and the DIC will say "low oil temp" all other gauges normal, Then it might run fine with the oil temp reading low, Then after stopping and restarting the temp will be normal again, and will run fine , Got home and there were NO codes. either C or H. and everything was normal again. What do you think? Thanks, Dennis.
Is it possible that the ign. switch could cause this? Dennis.
Here is the latest as of today. I Have replaced both the oil and coolant temp sensors. Just today, I straightened the female connectors in the driver door black connector again, and dabbed a little dielectric grease ,drive a mile or so and the engine cuts out DIC says low oil temp, and low coolant temp. Made it home, and had these codes . 10 PCM 1115HC and PO118 HC Yesterday I had driven about 30 miles and then started cutting out, made it home and had these codes U1160H P1114HC P1115HC DIC said lost comm. w/xxx. Question, Could the pass door connector be causing this? or maybe the connections behind the door panel? The batt. is 6 mo. old And reads 12.0 on DIC with engine off . is that too low? Some times it will act up as above and have no codes at all. Some times it will be ok for a couple hundred miles. Any help is greatly appreciated. Thanks, Dennis. P.S. could it be the ignition switch??
Reason: forgoe something.
NOT a good idea to apply to contact surfaces if that is what you did.
P0118 is reporting high resistance from the Engine Coolant Temp Sensor. High resistance is viewed as COLD by the PCM.
P1114 is reporting Low Voltage seen by the PCM. Low resistance equates to low voltage being seen by the PCM or an engine temp of 282F or more..
P1115 is reporting High voltage seen by the PCM. High resistance equates to high voltage seen by the PCM or an engine temp of minus 36F or more.
Since you replaced the temp sensor the sensor itself is unlikely to be the cause of these codes. The wiring between the temp sensor and the PCM is likely the cause.
I would pull the battery and the shelf it sits on and check for acid damage from a previously leaking battery. Wires to the PCM are directly below the battery.
Connector C2 has the brown wire from the engine temp sensor in position 60 which is the low reference. Connector C1 has the yellow signal wire for the coolant sensor in position 74. Likely the wire(s) are damaged between the PCM and the engine temp sensor causing the PCM to see widely varying resistance values..
You may also have a bad connector to the temp sensor.
Since the engine temp is a critical engine control input to the PCM the fact that is is seeing alternately very high and very low engine temps would cause the engine to run very erratically.
Thank you !! I will clean the grease off the contacts and check under the battery. Pretty sure there has been no leaking, but never know. This is driving me nuts.
In my view, there is a lot of misinformation on line about dielectric grease.
I have this view because I have been using it on low voltage electrical connections for over 20 years and have never had a problem with current passing through a well greased connection including battery terminals, frame grounds and multi prong connectors.
A test with an ohm meter across a well greased connection will show zero resistance. Give it a try.
My practice is and has been to thoroughly grease with dielectric grease every low voltage connector or ground that must be disconnected to do any work on any of four vehicles in my garage for at least two decades.
In 2009, one of the first things I did on my 2001 C5 was to disassemble and clean every ground and then assemble with liberal amounts of dielectric grease on and inside every part of each ground connection before tightening or plugging them back together.
A simple physical test with an ohm meter will show that dielectric grease does not interfere with electrical conductivity, and a thoroughly greased battery cable connection will pass hundreds of amps of current.
What dielectric grease does do is prevent air or oxygen from accessing the connection and causing corrosion. Corrosion products can separate even a very tight connection, causing an open circuit.
If the U1160 was listed under the 10 PCM then the PCM had lost communication with the LDCM..
That is not the same as an entire sensor module that has NO COMM next to its name.
When you list codes you need to take note of which sensor a Uxxxx codes is listed under. For example U1160 means loss of communication to the LDCM and there are several sensors that need to communicate with the LDCM so knowing which sensor lost communication can be important.
Perhaps you could pull the codes again and carefully look at each sensor to see if any one of them has NO COMM next to its name. I assume that you are pulling codes and not just expecting them to show up in the DIC automatically???
What I'm looking for is a situation where a single sensor causes major problems on the serial data buss that affects many other sensors since ALL sensors share the same serial data buss.
As of now , I have cleared all the codes. Is there a way to retain them after they cleared? I think the lost comm. w/xxx was when the codes were "10 PCM 1115 H C and PO 118 HC " and U 1160H. Thanks for your help. The car will run ok for a few mi. before the problems start again.
As I recall the DIC read " intermittent high and low voltage to coolant temp sensor"
If that is what was displayed in the DIC then that is exactly what I determined from the codes you posted above. When that is happening the PCM cannot use the coolant temp to properly determine how to control fuel and timing to the engine and as a result the engine will run erratically.
You need to chase down the electrical problem with the temp sensor. I suggested damaged wires and/or bad connector to the temp sensor. That should be a good start point.
A complete list of codes taken the next time the engine is running erratically BEFORE you shut off the engine will provide added input for diagnosis.
To pull codes with the engine running you must use the RESET button to clear any messages displayed in the DIC and then pull codes as normal.
OK thanks, I will do that. Just a little history . Had car since new, in around 2010 or so, the first prob. started, on a trip and all the gauges would shut off and DID went crazy, but car would run fine, after a few times of this happening I found the post about the driver`s door plugs, I pulled them apart and put back together, and no probs. for 6 years and 40-50,000 miles. Then a few months ago, the first prob. was on a run, and engine started cutting out and both temp s read high. DIC said 260+ and dash temp was pegged all the way hot. Thats when I replaced the coolant temp sensor, and every thing was good till a few weeks ago, then it did the same thing and the oil temp would read low. Now that sensor is replaced. Sorry to be so long winded , but maybe this will help to get to the bottom of this. Thanks, Dennis.
Usually when the black plugs in the drivers or passenger doors are problematic there are other tell-tail signs that are present. Often many different sensors will have codes (usually lots of Uxxxx codes which are loss of communications codes) or one or more sensors will report NO COMM next to the sensor name, or lots of messages will display in the DIC such as reduced power, ABS, TC etc. That is why I am interested in ALL the codes your car has stored after the symptoms occur.
The interesting thing about the two symptoms you are having (fluctuating coolant temp and low oil temp) is that the wires from both those sensors go back to the PCM which interprets the electrical signals and then sends messages over the serial data buss to the IPC to be displayed. Since leaking battery acid is a fairly common event on the side post C5's I would personally start with the removal of the battery and the tray the battery sits on and look for wiring damage from acid spills. One other possibility is the cumulative effects of excess heat from long tube headers over many years. Perhaps some wires have been cooked by that heat. Either way the area I would start with is around and under the battery since that is where the PCM is located.
If you can get the car up in the air I would also look at the battery positive connection point at the starter solenoid. Again the cumulative long term effect of excess heat from LT's is to fry wires and sometimes have the positive battery connection at the starter solenoid become loose.......
It has headers. ARH 1 7/8 longtubes since 2010, as matter of fact the first issue I mentioned was just a week after they were installed. I will def. get under there and check the solenoid wire. Sounds like a good possibiliy. Also, I will check under the battery. And thinking to pull driver door panel and check plugs in there. Thanks so much for the help! Maybe I won`t push this car over a cliff!! D.
I haven`t had a chance to get those things checked on the car yet. But this eve. I went out and turned on the key and the battery read 11.6 on the DIC. Even though its only about 7 months old , This seems like a pretty low reading. Went to 11.4 when turned headlights on. Then back to 11.5 11.6 with lights off. Do you think the battery might be the problem? With car running the DIC. is always between 13+ & 14+ volts. I replaced the battery 7 mo. ago when these probs. first started with the codes etc. As it was almost 5 years old at that time. And all was well for a few mo. till these latest probs. started. I know its poss. to get a bad new. battery. Its a Duralast Gold. Thoughts ? and thanks so much for the help!! D. Also, I forgot to mention that right after turning car off, the DIC reading immediately goes to 12 V or 11.9 . I remember one time when years ago I had stopped the car for a couple min. Got back in and started it the gauges and DIC went nuts, and ran rough for a few miles to home . and that batt. was 5 years old or so So I took ot right to Autozone and exchanged it and probs. were gone! I haven`t thought about the battery this time because its so new. Thanks again. D.
Reason: Forgot something.
When you read battery voltage using the dash gauges with the engine OFF and key ON the values that you see are all but worthless. The represent the "LOADED" battery voltage since many C5 electrical circuits are providing load when the key is in the ON position. Further, the ignition switch is between the battery and the gauges so any pitting/carbon buildup will further lower the numbers being read.
With the engine running you read approximately the output voltage of the alternator. Approximate because the starter solenoid connection is between the battery and the alternator and again the ignition switch is between the battery and the gauges. Loose or corroded solenoid connection and/or pitting/carbon buildup on the ignition switch will reduce the value being read on dash gauges.
To accurately know the battery voltage you need to use a digital multi meter across the battery posts, no key in the ignition and prefferably with the neg battery cable disconnected. That is because the hood light might otherwise be ON adding load and the BCM may NOT be in sleep mode and hence adding load.
Don't make any decision on battery replacement until you measure the battery voltage with a digital multi meter and also have the battery load tested. Most auto parts stores load test batteries free. Make 100% certain the battery is fully charged before it is load tested to get a correct evaluation of the battery. A good battery at full charge will measure 12.7 to 12.9 volts or more with no load on the battery.
I am still going to check the items listed above, But I`m starting to think I got a bad battery 6 months ago. Just went and checked the volts in DIC and analog. this morning and it was 11.3 11.4 I never remember it reading that low before, even after sitting for weeks. Will be taking back to Autozone for check and poss. replace. I remember similar problems, When it was time to replace batteries in the past. But it was always after 4-5 year s. Keeping fingers X`d that batt might be the prob.
OK I`m back. I`ve picked up some work the last few days so haven`t had much time to play with this. Today, I turned on key and DIC only read 11.3 , So I`m kind of thinking I got a bad Batt. 6 mo. ago. I know the DIC isn`t that accurate but 11.3 seems way low, It has always read around 12.0 in the past. As I recall when I had similar probs 6-7 mo. ago and raplaced the coolant temp sensor, and worked on the plugs in the doors, things kept happenning until I replaced the battery, which was almost 5 years old at that time. And everything was OK for 4-5 months and prob. 5-600 miles of runs. Then the same things started happening . I didn`t think about it maybe being the battery because it is new, I have it out of car and charging now, it is charging at 18-20 amps on a 10 amp charger. Also under the battery is bone dry so no leakage ! The specs on the Duralast Gold, battery are Crank amp-875, cold crank amp 700 , and reserve cap. 95 . Does that sound ok? Thanks again !! D. P. S. It always charges on gauges between 13 and 14+ volts.
Reason: forgot somethisng.
I did all the door plugs, the seat plug , there is no moisture in the pass. side footwell took cover off and all connections are dry & tight. Checked starter wires, all are clean and tight. none too close to headers. got done , hooked batt. back up, turned key on, all gauges and DIC, read normal ambient temps, Started car, No codes. Temps started coming up, took off around block, Then noticed coolant temp. was stuck on 97 deg. oil temp normal. got about 1/2 mile and car started misfiring and oil temp read low, coolant temp came up a little than read low. got home with car misfiring . charging syst. was 13 v. + Battery was reading 12.85 on voltmeter after charging and sitting all night with charger off. It read 13.5 + on DIC when all the stuff was happening. Got home left engine running went to codes, and there were no codes. All windows and door locks normal. Memory works, seat works. SO FRUSTRATED!. Could it be the ign. switch ? Any more help is greatly appreciated!!!! Just went to car, and turned key on and Batt was 12.3, coolant temp. was 117 & oil temp was 183.which is probably normal, car has been off for over 1/2 hour as I type. Thanks, Dennis.
Today, I changed the connector on the coolant temp sensor. Turned key on, and both coolant temp and oil temp read ambient temps around 67 deg. Started car, and ran codes, no codes, Drove around car ran fine, oil temp came up normal . Coolant temp came up very slow, oil temp got to 200+ and the coolant only read about 112 . Car ran fine no cutting out. Been about 1/2 hour, and just atarted it and oil temp is normal 200 + And DIC and guage coolant temp only got up to in the 130`s but the car is over heated and is blowing coolant out. Fans never came on. No codes at all . Call me stumped and frustrated.
Thanks, I have done that before, when changing coolant, Tried it this morning. and coolant temp was still reading 85 deg. and coming up very slowly, when oil temp. was at 150, And I could tell thermostat was opening and system was working. Still no codes, and everything else is normal. Thinking to change the temp sensor back to the old one and see if the new one is bad. The temp won`t read high enough for fans to come on, so that`s why it over heated yesterday in garage. Might there be any fuses that tie in the fans to read engine temp to turn on? Also before I started car, both temps read 57 deg. which was the outside temp in the garage. so it looks like the only problem is that the coolant temp. wont come up on the gauges to make the computer operate properly. Thanks again!!! D.
Just on a hunch from an old brain that still has a few working cells, I changed the coolant temp sensor back out with the oil temp sensor that I had changed during this ongoing saga. (They are both the same part) . Turned key on and coolant temp was right where it should be on both gauges! Went for drive and everything was normal!! Wouldn`t have suspected the sensor since it was new. But never know. Think I got it !! Thanks for all the help!!!
