FP relay location
Old Jan 16, 2018 | 08:37 PM
KJones's Avatar
KJones
Default FP relay location
Where the he!! is the fuel pump relay located on my 1999 Corvette?
Ken
Old Jan 16, 2018 | 08:38 PM
StingrayRebel's Avatar
StingrayRebel
the relay is in the underhood fuse box near the battery... the pump is in the driver side fuel tank
Old Jan 16, 2018 | 09:04 PM
KJones's Avatar
KJones
Thanks for the quick reply!
The relay is what I am after. Apologies for not saying that in my original post (old age getting to me)! I have looked in the fuse box but the legend in the cover does not show a Fuel Pump relay. Should I be looking for something else?
I am replacing the FP and want to replace the relay also.
Ken
There are 3 things you loose when you get old. One is your memory...... I forgot the other two......
Old Jan 16, 2018 | 09:10 PM
StingrayRebel
should be #35 on the diagram
Old Jan 16, 2018 | 09:18 PM
KJones's Avatar
KJones
Thank you kind Sir!!
Ken
Old Jan 16, 2018 | 09:23 PM
StingrayRebel
no problem... since you are going to replace it you might as well double check the connections inside the fuse box to ensure the new relay will make good contact
Old Jan 16, 2018 | 10:03 PM
KJones's Avatar
KJones
FOUND IT!!!
It is labeled F/PMP(imagine that!). Another alzheimer moment I suppose! (no wonder she won't let me leave the house alone)
Thanks for your patience and advice!
Ken
To FP relay location
