P0141 & P0161 codes
At this point I don't know what to do. Are the sensors bad? Did I wire them up right? Does the custom exhaust mean that I should be using something other than the stock post-cat sensors? Anyone have any ideas on next steps?
If you get catalyst efficiency codes with hi-flow or aftermarket cats and tuning them out is not an option, many times O2 spacers work.
To that end, here is the chart that I used to determine how the wiring should go:
https://www.screencast.com/t/C1MdD5ay
The new O2 sensor is a Bosch and it has 2 white wires, a black wire and a grey wire. Although I am not sure, I believe the old sensor is a Denso sensor and it has 2 black wires, a white wire and a blue wire.
When I wired them up I wired the 2 black wires from the harness to the 2 white on the sensor (each one separate), the white on the harness to the grey on the sensor and the blue on the harness to the black on the sensor. According to the chart, that should work but it throws the heater codes.
So I know what the colors are for the new sensor. The question is how do I determine what is what on the harness so I can connect them right if the configuration I wired them up in doesn't work.
Also, does the fact that I get 0.45 volts steady when I check with my OBDII have any significance? I know that the O2 sensors are supposed to output voltage between .1 and .9 volts so the 0.45 seams reasonable but it doesn't appear to fluctuate like the upstream sensors. Prior to changing out the sensors I wasn't getting any voltage on one of them so I figured that getting some voltage on them should be good.
Is there a way to test the wires on the harness to see what is connected to what?
