Reverse problems with 1999 6 speed manual.
Old Feb 6, 2018 | 08:40 AM
Nitro Neil's Avatar
Nitro Neil
4th Gear
Default Reverse problems with 1999 6 speed manual.
Anyone have a problem with shifting into reverse with 6 speed manual in a 1999 coupe? I changed the fluid in the slave cylinder already but it keeps getting harder and harder to put in reverse. It acts like the clutch isn't disengaging all the way but no problems in any other gears.
Old Feb 6, 2018 | 09:02 AM
98C5P's Avatar
98C5P
It could be your reverse lock out solenoid, they fail open or I think in your case, "locked" out.
Mine was open and I could buzz reverse...
It's a cheap part from rock auto, slight pain in the A$$ to change, but not bad.
Old Feb 6, 2018 | 10:19 AM
Moved to C5 Tech.
To Reverse problems with 1999 6 speed manual.
