Catch can hookup
Old Feb 11, 2018 | 12:35 PM
quick89's Avatar
quick89
Default Catch can hookup
1998 bought with this hookup, driver side PCV plugged, passenger side both ports capped. PCV to lower catch can port to FAST intake, upper catch can port to intake valley Will this work with both valve cover ports blocked off
Old Feb 11, 2018 | 01:24 PM
mykream's Avatar
mykream
You do not want the port on the passenger valve cover port capped off.
Otherwise, the catch can is hooked up to the intake mani and the valley cover correctly.
