Electrical problems
Old Feb 12, 2018 | 04:44 PM
old db 2001's Avatar
old db 2001
3rd Gear
Default Electrical problems
Fill up at station,pull away, and head lights pop up, lights on. switch will not control.
Start engine, driver side door open, A/C running, close door, A/C turns off. Must re start A/C.
Is a grounding problem, where do I start looking???
Old Feb 12, 2018 | 05:21 PM
JR-01's Avatar
JR-01
Any mods or changes made to electrical system?
Old Feb 12, 2018 | 06:00 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
I would start looking with the battery.
Old Feb 12, 2018 | 06:44 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
C5’s are prone to electrical problems. Battery is a good place to start. Did you check codes to see if something may pop up there that will give you a start?
Old Feb 12, 2018 | 07:24 PM
old db 2001
3rd Gear
None that I know of
Thank You for replying
old db
Old Feb 12, 2018 | 07:33 PM
old db 2001
3rd Gear
Will do
Had an 01 like yours, loved it, triple black. Should never had sold it.
Thank You for the great advice
old db
Old Feb 13, 2018 | 01:23 AM
Moved to C5 Tech.
To Electrical problems
