Dreaded Codes
Old Feb 15, 2018 | 10:48 PM
stingray76l82's Avatar
stingray76l82
Default Dreaded Codes
I have some issues the other day. Reduction of engine, security light, check gauges, and lost power to driver side window. open door its fine, close door now power? I pulled all the codes.The battery is showing 14.2 on start up. Thinking maybe a ground? Any help would be appreciated.
10 PCM 1626 H C
40 BCM U1255 H C
40 BCM U1016 H C
40 BCM U1096 H C
58 SDM U1301 H
60 IPC U1255 H
60 IPC U1016 H
60 IPC U1064 H
60 IPC U 1176 H
60 IPC U1088 H
60 IPC U1040 H
60 IPC U1160 H
99 HVAC U1064 H
99 HVAC U1096 H
99 HVAC U1160 H
99 HVAC U1255 H
AO LDCM B2262 H
AO LDCM U1255 H
AO LDCM U1064 H
AO LDCM U1016 H
A1 RDCM B2265 H
A1 RDCM U1255 H
A1 RDCM U1064 H
A1 RDCM U1016 H
A1 RDCM U1096 H
A6 SCM U1300 H
A6 SCM U1255 H
A6 SCM U1160 H
BO RFA U1255 H
BO RFA U1096 H
BO RFA U1016 H
Old Feb 15, 2018 | 10:54 PM
ant-knee470's Avatar
ant-knee470
Not sure but it sounds like you may have a bad wire in the door jamb... If you open door and all is fine I would suspect the door jam... Maybe broken or damaged wire.. Just a thought..
Ant...
Old Feb 15, 2018 | 11:19 PM
stingray76l82
Ant...
I thought of that to, but what about the other C code. I will check the the wiring harness at the door when I get some time off. Thanks for info.
To Dreaded Codes
