Drivetrain noise help!
Old Feb 22, 2018 | 06:22 PM
no vtec 4me's Avatar
no vtec 4me
Default Drivetrain noise help!
Since I've bought this car about 6 months ago i have noticed a drivetrain noise. It has gotten worse as time has gone on and is finally at a point its seriously starting to bother me. I tried to make a video that captures the sound as best as i can. It is worse when the car is cold, but still happens when warm. It is a rattle that sounds like it is coming from the rear of the engine, maybe a little further back (i would guess torque tube area). It is most noticeable when driving in first gear and letting off the gas coasting to a stop or slowing down to turn.
Any help is appreciated, check the link to the youtube video below.
Old Feb 22, 2018 | 09:17 PM
Moved to C5 Tech.
Old Feb 23, 2018 | 09:11 PM
no vtec 4me
No ideas? If the video isn't helpful i can try getting a better one.
Old Feb 23, 2018 | 11:32 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
mileage??..
edit: I looked at your other post...says 95K when you bought it
maybe torque tube bushings/bearings going bad
Old Feb 25, 2018 | 02:49 PM
no vtec 4me
Originally Posted by pewter99
mileage??..
Yea, about 98k now. That was my first thought, but the noise doesn't seem to be the same as other youtube videos I've watched of torque tube noises.
Old Feb 26, 2018 | 01:00 AM
gimp's Avatar
gimp
That creaking rattle noise?
Could be your exhaust rattling, could be heat shield related stuff. Get under the car with it on (safely) and poke around. If it's coming from the bell housing, you'll probably be looking at a pilot bearing, throw-out bearing, torque tube coupler, or torque tube bearing - any of which usually mean you're doing a clutch job.
Old Feb 26, 2018 | 08:24 AM
runner140*'s Avatar
runner140*
A while back, I had a noise....thought it was the torque tube.....with further investigation, turned out to be a wheel bearing. Sometimes they test ok but are not.
To Drivetrain noise help!
