dead car
Old Feb 23, 2018 | 07:38 PM
deonmas3's Avatar
deonmas3
4th Gear
Default dead car
My battery was over charging, I figure It to be my alternator, because my battery was getting really hot, so it died, but while the car was in neutral, had car towed home replaced battery, now the car want start, go into park or do anything!!!! really need some help oh yeah its a 03 c5 vette!!
Old Feb 23, 2018 | 11:29 PM
Jacks02's Avatar
Jacks02
Suggestions: Record the codes on the DIC, look them up, repair the fault(s). If DIC is inop, look under the battery tray and everywhere else to inspect wires. If you find they are fried, consult a good automotive electrician. (If you find one at a dealership, TELL EVERYONE on this Forum -- that's NEWS!)
Old Feb 24, 2018 | 06:34 AM
Moved to C5 Tech.
Old Feb 24, 2018 | 09:37 AM
ant-knee470's Avatar
ant-knee470
The car wont go into park?? Did something get damaged from towing?
Ant...
Old Feb 24, 2018 | 12:59 PM
deonmas3's Avatar
deonmas3
4th Gear
Ant...
No I don’t think so it seems as if it’s stuck in neutral,also the gages still have readings such as a temp reading for fluids , as if it still sees the last reading when it lost power
Old Feb 24, 2018 | 01:01 PM
deonmas3's Avatar
deonmas3
4th Gear
All the codes say no codes but I reset them anyway. ???????????
Old Feb 24, 2018 | 03:15 PM
ant-knee470
if the car went into park prior to being towed I would suspect something happened from tow.. Car does not need power to get into park...
Old Feb 24, 2018 | 08:50 PM
UM Rebel's Avatar
UM Rebel
Not sure what you mean, will not go into park. Will shift lever move to park position but transmission is not in park or can you not move the shift lever to the park position?
Old Feb 25, 2018 | 10:07 PM
deonmas3's Avatar
deonmas3
4th Gear
Figured it out, the shift cable popped lose, worn out bushings,bought a new one, is there a video on how install the new one and get the old one off
Old Feb 25, 2018 | 10:12 PM
ant-knee470
Ive never done the cable, But I have heard it is a PITA...
Someone will chime in ...
Good luck,
Ant...
Old Mar 4, 2018 | 01:52 PM
UM Rebel's Avatar
UM Rebel
Did you get it fixed? If not, which end did it pop loose from, front or back?
If front, remove center console (lots of videos on that). Remove 4 10mm nuts holing shift lever on. Be careful with the shift cable it can not bend very far without breaking. If it breaks you will have to replace entire cable. Get any remaining part of old bushing oug. Position new bushing in place.With shift lever leaning to passenger side position pin ready to insert. Reach in with a long handle channel lock or needle nose locking priers. Snap the pin into the bushing. That's it. Put everything back together.
If it's the rear, I found it easiest to remove the shift lever from the transmission. Pop the pin into the new bushing. Then reinstall shift lever. You may have to also drop axle back of exhaust to get to the shift lever.
Just one more time. Don't try to bend the shift linkage very far. It will break and replacing the entire linkage is a PITA!
To dead car
