Camshaft replacement question
Old Feb 26, 2018 | 06:08 PM
Titan22's Avatar
Titan22
Default Camshaft replacement question
When your changing a cam on a c5 do you have to completely remove the condenser or are you able to roll it up and out of the way?
Thx
Old Feb 26, 2018 | 06:56 PM
Spaceme1117's Avatar
Spaceme1117
Thx
No, you don't have to remove the condenser. You should be able to move it just enough to get the old cam out and the new cam in.
Check out LS1HOWTO.com. They have to whole install written up with pictures. The do head removal and installation but only because they are swapping heads and lifters. If only a cam install, no need to do that.
Old Feb 27, 2018 | 09:12 AM
feeder82's Avatar
feeder82
I had to have another person hold the condenser while I pulled the cam, you don't need to remove it, but you probably will need a extra set of hands
Old Mar 1, 2018 | 08:47 PM
gnharley's Avatar
gnharley
Default Cam change
I used the LS 1 how to directions , just changed cam , gears , chain , oil pump & added chain tensioner , drilled & pinned the crank & balancer (25% underdrive) I cut some 8"-10" wedges out of 2x4's to push the condenser up just enough to give me a little extra room to work , cam cleared easy. I did the entire job by myself (no "x-tra" hands , nowhere !) I'm almost 70 .
Old Mar 1, 2018 | 10:36 PM
PDQC5's Avatar
PDQC5
You may find the fins really plugged up
To Camshaft replacement question
