Steering?
Old Mar 4, 2018 | 05:11 PM
sloopdawg's Avatar
sloopdawg
Default Steering?
While replacing my end links I noticed ( i'm guessing steering bushings) are going. What are these called? Where can I get them? I guess if I knew what they are called I could look them up. I looked through the Service Manual but must have missed it. Anyone with a manual know what page? Steering stuff is in Chapter 2 but didn't see anything that looks like it. Thanks in advance.
Old Mar 4, 2018 | 05:42 PM
Proletariat designs's Avatar
Proletariat designs
Tie rod end. You'll have to get an alignment after you install them.
Old Mar 4, 2018 | 05:47 PM
sloopdawg's Avatar
sloopdawg
So are they tie rod bushings that I'll need? Is it the rubber part or the whole piece? Sorry for being so naive.
Old Mar 4, 2018 | 05:51 PM
Proletariat designs
No worries I'd get the whole thing. I don't think I've seen the cover sold separate.
Old Mar 4, 2018 | 05:55 PM
sloopdawg's Avatar
sloopdawg
This?
tie rod end tie rod end
Old Mar 4, 2018 | 05:59 PM
Proletariat designs
GM/Delco part numbers:
88910455 Front
88955488 Rear
That one will do the job. Now is a good time to look at bump steer kits. Inspect the rear ones as well. Chances are they need replacing too. I think the rears are longer than the front so don't buy 4x of the front outers.
Old Mar 6, 2018 | 07:56 PM
gnharley's Avatar
gnharley
88910455 Front
88955488 Rear
When you take your old ones off count how many turns it takes to unthread them off the tie rod , thread your new ones in the same amount of turns , that will get you close enough (to proper alignment) to drive the Car to an alignment shop.
To Steering?
