Has anyone taken the tunnel plate off of their C5Z and measured the thickness? I’ve searched and searched and it appears that all C5 tunnel plates are likely the same 1/16” thickness; however, I did see where someone mentioned that the C5Z got a 1/8” think plate. Just want to clarify before I buy a used 1/8” plate off a C6.
I'm making one out of titanium.... .035 thick because of its stiffness and resistance to heat transfer..... the cuts are pretty simple and i have a nice drill press just sitting there... grade 2 titanium sheet is about 200 bucks for the material needed...
I put one of the Elite Engineering (I think it was theirs) tunnel plate in my car YEARS ago. I did, however, keep the OE plate, and just came across it a few weeks ago, as I was attempting to straighten up my basement.
Since I knew where the OE plate was, I could locate it easily, so I went downstairs and measured it. It came out at 0.062".....1/16".
Neither really blocks any sort of heat unless you coat it or apply a thermal barrier. Even then, it's not much. You'd be better off applying an insulation layer under the carpet. Once I did that to mine, I get VERY little heat from the tunnel. On super hot days, the center console will get a bit warm, but that's it.
There is a noticeable stiffness increase from the thicker plates offered by the aftermarket. I noticed mine pulling out of my apartment complex. The car creaks a LOT less when transitioning from the parking lot to the road.
I did a tunnel plate sandwich. Bought a C6 plate for cheap on eBay, then smashed a layer of heat shield between the stock C5 and C6 plates and bolted them up. I noticed some decrease in temps and increased thickness. Plus it was around $80 all-in. The stock screws are long enough to accommodate stacking the two plates.
Thanks for all the responses. I contemplated the C6 plate since I can get one for $25 and I need to remove mine anyways for a clutch. I figured if it was even marginally better then what the hell. I will think about it more and look into the Elite Engineering piece, just not sure there is enough benefit for me there given the cost. If I had a targa top or vert I'd definitely buy one. I’m most interested in potentially stiffening the chassis but don't necessarily have any issues with it as is. Believe it or not, I can’t say I ever noticed a hot console/shifter/interior with my stock tunnel plate even at the road course.
To the person making one out of titanium, that’s freaken cool!
