Broken Tits? (window seals)
Old Mar 7, 2018 | 08:34 PM
whalepirot's Avatar
whalepirot
Default Broken ****? (window seals)
Two of the plastic "rivets" that hold the outer window seal were broken on the R side, plus the aft-most on the L side, when I did some work that required removing the interior panel. The seals are fine, pliable etc.
New replacements are $35-$75/ea +/-, which is a waste of cash, as those rivets are available. Initially, I thought they were molded into/along with the seals, but drilling out the centers, readying each for replacement, I discovered they are push-pin rivets. I did have to enlarge the holes slightly for the replacements.
The 'auction place' kit of assorted rivets and tools employed:
Actually this type had a plastic phillips head, which didn't do well against my mighty wrist, so I employed the smaller push-pin type.
Fourteen bucks and some time.
Old Mar 14, 2018 | 09:03 PM
Sam Handwich's Avatar
Sam Handwich
I had a similar problem with my "****". Drilled a hole in the place where the break occurred. I used some nylon machine bolts and superglue; and then I used the Super-glue plus baking soda trick to make sure the bond was solid.
My **** look and feel much firmer after the plastic surgery.
YMMV
Old Mar 17, 2018 | 12:55 AM
Brad Kirby's Avatar
Brad Kirby
LMAO after reading that title.
To Broken Tits? (window seals)
