2002 corvette insert key security light goes out after a few seconds turn key to start engine and nothing happens any suggestions or advice.new battery and fuses OK. security issue?
Could be a security issue .
Check if the PPL wire on the starter get 12 volt when you try to start the engine . If you not get 12volt on the purple wire on the starter solonoid , then you should check why the Theft Deterent Relay not supply the 12volt from fuse 52 to the starter .
Most likely your starter solenoid, have somebody place a wooden broom handle on the starter and have them rap the broom handle with a hammer or other object while you try to start. Previous advise to check for 12v on the purple wire is something I always recommend, that will prove that the problem is the starter if 12v is present, or upstream interlocks such as TDR, clutch safety switch if manual, or neutral safety switch if auto if there is no 12v on the purple wire.
