Fuel Pressure Regulator
Old Mar 12, 2018 | 05:19 PM
Tevroc98's Avatar
Tevroc98
Default Fuel Pressure Regulator
I'm using a 2001 LS6 motor in my restomd. I'm using the stock fuel pressure regulator. The side with the two outlets. Which is the return and which is the inlet? Or doesn't it matter?
Old Mar 13, 2018 | 05:35 AM
oelarse's Avatar
oelarse
Yes , it does matter .
If you enter fuelline from the pump to the returnport the regulator will not work .
Old Mar 13, 2018 | 08:02 AM
Tevroc98's Avatar
Tevroc98
Thank you .I appreciate the info. I thought that was the setup but wasn't sure.
To Fuel Pressure Regulator
