for the answer to your first question I would ask rpm or Rick at rkt56... I used rkt56 conversion mounts on my 6060 swap... the oem mounts will not work because the mounting points are offset when you install the drivetrain into a c5, I think this is because the torque tube is shorter in the c5 but I'm not 100% sure... if that is the case I wonder if a c6 torque tube would work and then you could use the oem mounts
