I have an intermittent Blinker and No emergency flasher problem. I can't seem to narrow it down to moist weather or anything. I wonder if there is a Relay maybe that is sticking.
I am sure that the more experienced may can offer an idea. I did take the car in , but was not intermittent enough for them to troubleshoot.
The flashers are built into the "Hazard Switch" a lot of them are going bad after a few years. I had one changed in my OLDSMOBILE that had the same problems. It was a $25 switch. You have to remove the dash on the C5 to change the switch. I would let the dealer change mine ..
Search "Turn Signal" and you will find more posts about this condition.
I might want to use a different dealer, this is a common condition with all new GM cars . Bill
