Trim Height Question
After lower my Vert (8 bolt full turns each bolt) and driving a few hundred miles, I verified my ride height.
The fronts are very close 02/16ths difference..which I believe equates to 1
mm.
However the rears were way off. So I raise the passenger side 2 full turns of the bolt and now have difference of 03/16ths.
The manual does not indicate one should sit in the car to set ride height.
(FYI..with my weight in seat rear is 3-3/16 and 4-5/16)
I can not believe the height was so far off from the factory.....based on evenly turning the bolts.
Help/ comments please. Thank you in advance.
