abs brake light stays on
Old Mar 31, 2018 | 03:16 PM
richardcarriker's Avatar
richardcarriker
2nd Gear
Default abs brake light stays on
Is it possible to get the warning light on the dash to turn off? I don't need that level of braking control since I never drive my 2001 C5 fast
Old Mar 31, 2018 | 03:46 PM
JR-01's Avatar
JR-01
Pull your codes to get an idea what the problem may be.
Turn on the ignition but don't start the engine.
Press the "reset" button to turn off any warning messages
Press and hold "options" and
While holding "options", press "fuel" four times within a 10-second period.
http://www.c5forum.com/ayc/dtcdic.php
https://ls1tech.com/forums/corvette-...they-mean.html
Old Mar 31, 2018 | 04:09 PM
richardcarriker
2nd Gear
Thanks JR. Just tried and could not get the warning light "service ABS" to turn off. Pressing/holding "options" and pressing the "fuel" didn't have any effect either. Key was turned on but did not start the engine.
Old Mar 31, 2018 | 04:12 PM
Smoken1's Avatar
Smoken1
There are over 2 dozen codes that will turn that light on
Old Mar 31, 2018 | 04:35 PM
449er's Avatar
449er
CF Community Team
Yes you do need that "level" of braking control, you could have a catastrophic crash depending on what code is lit, get it fixed!
Old Mar 31, 2018 | 08:30 PM
Moved to C5 Tech.
To abs brake light stays on
