Flow numbers and stats on new heads...
Old Oct 16, 2002 | 10:33 AM
Phil97SVT's Avatar
Phil97SVT
Default Flow numbers and stats on new heads...
I just got my new heads finished and here is the result. The heads have a 56 cc compression chamber which equates to 11.75:1 compression. :eek:
Flow: Exhaust - Intake
.100 - 54 - 70
.200 - 111 - 140
.300 - 148 - 203
.400 - 195 - 252
.500 - 242 - 284
.550 - 249 - 296
.600 - 252 - 303
Any thoughts? :yesnod:
Phillip
[Modified by Phil97SVT, 3:35 PM 10/16/2002]
Old Oct 16, 2002 | 10:40 AM
QwikSilvr's Avatar
QwikSilvr
Default Re: Flow numbers and stats on new heads... (Phil97SVT)
Phil, looks like you're going to need to run rocket fuel in that beast to keep the detonation away ;) Those are some good numbers....
Frank
Old Oct 16, 2002 | 10:43 AM
Phil97SVT's Avatar
Phil97SVT
Sunoco 94 and pull the timing alittle for pump gas. :yesnod:. 110 octane race gas and 30degrees of timing should make me :crazy:.
Phillip
Old Oct 16, 2002 | 12:33 PM
LT4POWR's Avatar
LT4POWR
11.75:1 CR and you plan on putting a turbo on???
Old Oct 16, 2002 | 12:41 PM
EuG's Avatar
EuG
Phil,
Looks good, but flow numbers by themselves don’t mean much. :nono:
There’s MANY variables and all flow benches are different so you can’t really compare them at all :nonod:
Old Oct 16, 2002 | 12:56 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Flow numbers and stats on new heads... (EuG)
Your 100% correct. I was posting numbers to add some information to the forum members. I will use this inconjuction with dyno graphs to make them make sense.
Phillip
Old Oct 16, 2002 | 01:14 PM
RWE 427's Avatar
RWE 427
Veteran: Marine Corps
Default Re: Flow numbers and stats on new heads... (LT4POWR)
I agree thats alot of CR for a turbo! It should be fun while it lasts. :D Have fun! :cheers:
Old Oct 16, 2002 | 01:18 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Flow numbers and stats on new heads... (RobsC5)
NO NO NO, 11.75:1 is my all motor setup. I am probably going to 9.0:1 with the turbo which is down the road. Actually after calculating it I think it is going to be closer to 12.0:1. :eek: :crazy: :yesnod:
Phillip
Old Oct 16, 2002 | 02:03 PM
Moundir's Avatar
Moundir
Phillip
12.0:1 :eek: :eek: You are nuts dude :yesnod: I guess you should have no problems running your 10.9s with this heads with a good cam :yesnod: Good luck and keep us posted :seeya
Old Oct 16, 2002 | 02:34 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Flow numbers and stats on new heads... (Moundir)
Just for thought once I get the valve reliefs cut I am going to either a 232/232 .610 112lsa or a 234/230 .610 .610 112lsa. Maybe this will make some more horsepower. :crazy:
Phillip
Old Oct 16, 2002 | 05:51 PM
LT4POWR's Avatar
LT4POWR
That makes sense.
Keep us posted.
:cheers:
Old Oct 16, 2002 | 07:21 PM
vstella's Avatar
vstella
FWIW..I just got back my heads from ARE and the #'s are very similiar..I'm running 31 degrees timing and the A/F is kinda lean at 13.1...I was thinking maybe Z06 injectors to fatten it up just a little..I'd like to be in the 12.7 range..
Old Oct 16, 2002 | 07:47 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Flow numbers and stats on new heads... (vstella)
Vince,
What kind of compression ratio are you running? From my old dyno pulls where I made 421/400 I am going up 1.2:1 in compression ratio and 20cfm on the intake and exhaust runners. Kinda makes ya think.
Phillip
:crazy::crazy::crazy::crazy::crazy::craz y::crazy::crazy::crazy::crazy::crazy::cr azy::crazy::crazy::crazy::crazy::crazy:: crazy::crazy::crazy::crazy::crazy::crazy ::crazy::crazy::crazy::crazy::crazy::cra zy::crazy::crazy::crazy::crazy::crazy::c razy::crazy::crazy::crazy::crazy::crazy: :crazy::crazy::crazy::crazy::crazy:
[Modified by Phil97SVT, 11:48 PM 10/16/2002]
To Flow numbers and stats on new heads...
