Passenger side window
Old Apr 6, 2018 | 05:19 PM
WKM's Avatar
WKM
Default Passenger side window
Anybody have an issue with there power window? After sitting under the shelter with the top up most the winter took it out today and put the top down. Noticed the driver side window went down normally but the passenger side didn’t. When I got home and put the top back up I tried the passenger side and nothing happens. If I listen closely as I mash the button I can here the relay click in the door but nothing happens. Any thoughts or anyone have this issue?
Old Apr 6, 2018 | 05:44 PM
Vanover's Avatar
Vanover
Your regulated is going bad. Hit the inside door panel firmly with your hand it might work a few more times. But it’s going to need to be replaced.
Old Apr 6, 2018 | 07:31 PM
WKM's Avatar
WKM
I was afraid of that. What kind of expense is it to have replaced?
Old Apr 6, 2018 | 08:11 PM
sloopdawg's Avatar
sloopdawg
Old Apr 6, 2018 | 09:07 PM
WKM's Avatar
WKM
Thanks Sloopdawg
Old Apr 7, 2018 | 12:11 AM
Moved to C5 Tech.
Old Apr 7, 2018 | 09:10 AM
rrwirsi's Avatar
rrwirsi
If hitting to door panel does not work, try this method. Although your regulator could be the problem, sometimes electric motors have flat areas (so I have been told) and get stuck. I did mine using this method about a year ago and have not had a problem with it since.
File Type: doc
Old Apr 7, 2018 | 01:26 PM
WKM's Avatar
WKM
Rrwirsi thanks for that post went out tapped it one time and it started working. I guess after not being lowered for several months it just stuck
To Passenger side window
