TRICKS OR TIPS on replacing shifter cable
Old Apr 10, 2018 | 07:06 PM
Rene's Rage's Avatar
Rene's Rage
Default TRICKS OR TIPS on replacing shifter cable
Cable is broken. I do not want to remove intermediate pipe and tunnel cover. Thinking about making my own access hole on the drivers side of the console with a three inch hole saw to get to the cable bracket. I think I can lower the exhaust at the transmission enough to get my hands to the transmission bracket. Is anything else securing the cable to the inside of the tunnel. Any advice would be greatly appreciated.
Old Apr 10, 2018 | 11:39 PM
Moved to C5 Tech.
Old Apr 11, 2018 | 07:20 AM
feeder82's Avatar
feeder82
You can use the old cable to pull the new one thru the tunnel, it's a 2 person job. Use a ziptie to hook them together
Old Apr 11, 2018 | 07:40 AM
Simtech's Avatar
Simtech
Are you sure it is broken and one of the bushings on the end hasn't disintegrated, They all seem to do this and it is a 5 dollar fix.
Old Apr 11, 2018 | 08:06 AM
GCG's Avatar
GCG
Probably there's no need to replace the whole shifter cable. What usually happens is that the bushings are gone and they are the only things that need to be replaced.
All you need is the
<b>Dorman 14057</b> Dorman 14057
kit. Use the white bushings (the orange ones are for Ford):
And
shows you how to do it.
Old Apr 11, 2018 | 08:38 AM
runner140*'s Avatar
runner140*
All you need is the Dorman 14057 kit. Use the white bushings (the orange ones are for Ford):
And this video shows you how to do it.
Thanks, guys like you save guys like me a lot of money.
Old Apr 11, 2018 | 11:15 AM
Rene's Rage
The bushing at the shifter broke and in the process of fixing the bushing, I broke the cable.
I tried to remove the exhaust manifold nuts but they are too rusty.
Have read all the posts and videos on how to replace the cable.
Just wondering if anybody had any tricks. Thanks
Old Apr 11, 2018 | 02:20 PM
GCG's Avatar
GCG
If that's the case take a look at this thread, especially Post 1 and Post 4. It seems it can be done even without having to cut an access hole as you mentioned.
To TRICKS OR TIPS on replacing shifter cable
