LS2 cam in stock LS1 worth it?
Higher ratio rockers are not a common mod as most just go ahead and swap to a bigger cam. Further, if you are building in steps to get to an end goal, cams are generally designed to be used with stock rockers.
I used google to search the forum
https://www.corvetteforum.com/forums...8-rockers.html
https://www.corvetteforum.com/forums...good-idea.html
