C5 parking brake sensor / switch- light on dash
Old Apr 11, 2018 | 12:32 PM
Pat Tucceri's Avatar
Pat Tucceri
Default C5 parking brake sensor / switch- light on dash
I’m getting a BRAKE light on the dash for a while now, it used to go on and off on it’s own... now it’s on 24/7 when the cars running. I’m trying to text or by pass the Handel sensor... can anyone help... I tried playing with the contact, nothing. I’ve unplugged the sensor.. nothing.
Pat Tucceri
Old Apr 12, 2018 | 07:37 PM
Pat Tucceri
please help!
Old Apr 13, 2018 | 10:41 AM
GCG's Avatar
GCG
Have you checked your pads? The light might be steady on now (even if ebrake switch is unplugged), after a period in which it was on and off, because brake fluid sensor might be saying fluid is low due to pads that need replacement.
Old Apr 14, 2018 | 12:12 PM
Pat Tucceri
I have not, the fronts are all new I replaced them not to long ago- I’ll have to check the rears. It also has been displaying “low brake fluid” on the dash.... so you think it’s the pads and has nothing to do with the switch? That would be awesome- fix two issues with one!
Old Apr 14, 2018 | 01:20 PM
GCG's Avatar
GCG
It seems that there you have your answer! Brake fluid is low. Check your pads, but also check for leaks.
To C5 parking brake sensor / switch- light on dash
