Courtesy Lamp Relay Replacement
Old Apr 12, 2018 | 06:11 PM
smagray04's Avatar
smagray04
Default Courtesy Lamp Relay Replacement
The footwell and trunk lights on my 04 stopped working. If these are the "Courtesy Lamps", they run through relay #42 in the under-dash fuse block. I tried removing the relay, but could not pull it out. I can certainly live without them, but I would like them to work if it's not a big $$ fix.
