Replaced Right Sending Unit, Still Acting Up
I have a 2001 C5, and replaced the right side fuel pump assembly, which worked OK for about 6-8 months. Then it would only read 7/8 full on fill up, then sometimes, after 100 miles after fill up, it would drop to 0, requiring I reset the code.
I tried several bottles of Techron, with no difference, so I took it to the dealership, who used a detailed scanner/computer, and said the right side fuel pump assembly was defective, and quoted me $1000 to replace it. I bought the assembly off Amazon for a little over $200, and had it replaced in a little over an hour, taking my time. I had run the fuel below 1/2 tank, so I didn't have to drain anything, since the right side empties before the left side.
Any suggestions on how to fix it permanently, or is this going to be an ongoing issue?
I had tried the Tectron treatments for over a year, but it never did fix my problem.
I also had a reflash done on the PCM concerning the fuel guage on the c5.
After both of these things being done I have had no more problems with the fuel guage going to zero.
If I were you I first would pull the codes from your car then post them up here and others will help you with your problem.
The reason I went ahead and pulled and cleaned the units was the ease of the job and then would know that they were clean and not the problem.
The re-flash of the PCM was also another step that I went ahead and did for added security. It cost me $25.00 at the dealership.
GM Service Bulletin TSB 02-06-04-010A
Good luck with your repair.
I have owned GM vehicles over the years, and the C5 is the first I have had with fuel gauge issues. It doesn't happen after every fill up, so for now, I am resetting the PCM code to get the gauge working again.
I had the tuner who did a tune for me disable the code that caused the gauge to fall to empty, but he forgot to include it when he reflashed the latest PCM code, so about 6 months later, it started again. The tune the guy put in had a few things I liked on top of the fuel map and timing alterations. It eliminated the 1st to 4th lockout and also cut the electric fans on at a lower temperature. The car stays much cooler now, hardly ever over 200 degrees. Only cost $150.
