Trans problems caused by mass air flow sensor
Old Apr 17, 2018 | 07:29 PM
Awkwardcrane's Avatar
Awkwardcrane
Default Trans problems caused by mass air flow sensor
I've been searching old threads and didn't find anything.
Do any of you know whether a problem with the mass air flow sensor can cause the transmission to prematurely wear out? Loose a gear?
Old Apr 17, 2018 | 08:19 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I would say NO !!!!
Old Apr 18, 2018 | 11:17 AM
glbeauchamp's Avatar
glbeauchamp
Don't see how that could occur. I vote NO too.
Old Apr 18, 2018 | 11:42 AM
Awkwardcrane
I had my A4 rebuilt last summer. It wasn't making the 1-2 shift. I took the car to a very reputable shop, the owner used to teach transmission repair at the local community college and have had them work on work trucks we owned for over 20 years.
A month ago the trans started acting up again, took it back and went for a ride with one of the techs and with a computer hooked to OBDII he could see it wasn't making 1-2 shift again. He suspected a solenoid or servo. I picked the car up yesterday, they had to do a rebuild again, said 2nd and 3rd were gone? They did not charge me for the rebuild but did install a new MAP sensor and said there was some info that these could cause trans problems but couldn't prove that it did in this case, just doing it as a precaution.
When I got home I searched for this kind of problem. I found the article at the link below. There are more articles concerning Chevy vehicles, just wondered if anyone else had experienced this.
http://www.samscars.com/gf87.html
Old Apr 18, 2018 | 12:57 PM
lionelhutz's Avatar
lionelhutz
My answer would be yes. The PCM is calculating engine torque to control the line pressure so any issue that throws the torque calculation off on the low side could potentially damage the transmission.
Old Apr 18, 2018 | 01:50 PM
Awkwardcrane
If yes, would it show in the DTC ?
I show no codes with the PCM. A few door control issues only.
I did have an engine check light come on the day before putting it up for the winter however it didn’t show when I started it up a few weeks ago.
Old Apr 18, 2018 | 02:04 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
strange I thought increased line pressure was better, tuners do that all the time ??????
To Trans problems caused by mass air flow sensor
