Transmission chirp
Old Apr 21, 2018 | 02:02 PM
Martin2D's Avatar
Martin2D
Default Transmission chirp
What I thought to be a pulley making nose is probably transmission or torque tube related. Seems to be conflicting information on all the threads I've read regarding what this may be.
Symptoms:
​​​​​​Constant chirp in neutral.
Disappears when clutch is depressed.
No noise when gears are engaged or moving ou fluctuation with RPM.
I've seen responses of similar problems from throw out bearing, pilot bearing, or torque tube bushings to don't worry about it.
Any advice would be greatly appreciated.
Old May 1, 2018 | 04:16 PM
Martin2D's Avatar
Martin2D
Made a video. The loud noise is me depressing the clutch pedal.
https://photos.app.goo.gl/dVPHsh4BXGSobKof8
Anything to really worry about?
