BAER Rotors - Quality Issue
Old Oct 17, 2002 | 09:07 AM
BostonVette's Avatar
BostonVette
Default BAER Rotors - Quality Issue
Has anyone else experienced an oxidation problem with the aluminum hats on BAER rotors.
I installed a set of Eradispeed plus +1 about a month ago. I soon noticed a white flakely substance growing on the rear aluminum hats. The stuff doesn't wipe off very well and I didn't want to use any chemicals until I talked with BEAR. Strange thing is that the fronts are in pristine condition
I assume the hats are anodized and while anodizing may not hold up forever, I would have expected more than a month.
My buddy has a similar set and he has the same problem, rears only.
I contacted BAER several times during the past week, but they are not respondinding.
These rotors are pretty expensive, I would expect a more durable finish and quicker response to a customer concern.
Anyone else have a similar experience?
Thanks Tom :mad
Old Oct 17, 2002 | 11:24 AM
Mad_Dog's Avatar
Mad_Dog
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: BAER Rotors - Quality Issue (BostonVette)
I have had mine going on a year now with no problems -- front or back.
Old Oct 17, 2002 | 12:45 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
No problems with mine either. Maybe it's the Massachusetts water you're using to wash them!!! :cheers: :cheers:
Old Oct 17, 2002 | 01:19 PM
RichS23's Avatar
RichS23
Default Re: BAER Rotors - Quality Issue (jw38)
I also have not had any problems. However, I have the two piece and I think I have the different hats.
It could be the area of the country you live in. It may be a lot cooler and damp which would promote the 'white flaking'
Old Oct 17, 2002 | 01:43 PM
BostonVette
Could be the water here!!!
They actually made a movie about the water in my city, Richard Gere starred as the lawyer in A Civil Action.
Seriously, They haven't seen much water or moisture in the month that have been installed.
To BAER Rotors - Quality Issue
