'99 Fob will not program ?
Old Apr 25, 2018 | 03:05 PM
rjs209's Avatar
rjs209
Default '99 Fob will not program ?
Bought brand new GM Fob for 1997 - 2000. It will not program using the in car method. My "older" one programs fine. It is also a "2000" style with out the "passive switch" Was told it is not uncommon and needs to be done at dealer?
Old Apr 25, 2018 | 04:59 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
does your TPMS work ?? RFA module could be bad ???
Old Apr 25, 2018 | 05:05 PM
BRAVO1's Avatar
BRAVO1
VETERAN
I stood in front of the car and pressed the button.....B I N G O
Old Apr 26, 2018 | 10:09 AM
rjs209's Avatar
rjs209
Originally Posted by 8VETTE7
Should be absolutely NO REASON to have a FOB programmed at a dealer. GM put the procedure in the Owners manual so that the OWNER could do the programming.
Have you verified the battery is indeed a good battery in the new FOB?
The issues with the early year FOB's were poor solder joints on the tiny circuit board for the battery connection as well as components on the board. Would not surprise me if the one you received had that problem right from the start:
http://forums.corvetteforum.com/c5-t...em-solved.html
Takes a good magnifying glass and good eyes to see the tiny cracks and poor solder job if you decide to open the case of the FOB and look.
Many dealers have a device that can be used to determine if the FOB is even transmitting. Some parts stores also have a similar device. I would start there.
Kinda what I thought.
Brand new battery. I will have the fob checked to see if it does send signal.
Thanks!
Old Apr 26, 2018 | 10:11 AM
rjs209's Avatar
rjs209
TPMS works fine. Must be the FOB.
Thanks!
To '99 Fob will not program ?
